Ansys Learning Forum Forums Discuss Simulation Fluids question on particle deposition with the turbulence dispersion in pipe flow Reply To: question on particle deposition with the turbulence dispersion in pipe flow
Hui Wang
Hi Rob, thank you for your reply! Very sorry for the delayed response!
The height of the first cell is 2E-05m (center of the cell), and the diameter of droplet is 1.4um-21um.
In my case, the turbulence dispersion should drive the particles deposits on the pipe wall. Actually, i model this case just following a research paper with the name of  "Towards quantitative prediction of aerosol deposition from turbulent flows", the conclusion is that "The use of isotropic turbulence models resulted
in over-prediction of V+ by more than 3 orders of magnitude for tao_plus 0.2, whilst the anisotropic RSM gave results in good agreement with experiment. " But in my case, even i use the same model settings as the research paper, there is little deposition for the case of 1.4um (tao_plus 0.2). In fact , a lot of research papers show the same results. So i am really confused. It seems that the particles are getting stuck in the boundary layer and never colliding with the wall.
The attached link https://www.researchgate.net/publication/222936725_Towards_quantitative_prediction_of_aerosol_deposition_from_turbulent_flows shows the reference paper.
BTW, how can i show you my case in this forum?
Thanks in advance!
