oglawal2
Thanks I didn't realize I made a blank post. Actually Im just trying to figure out the impact force. Im simulating impact collision on a bridge. But sometimes with higher initial velocity I get lower peak force than a lower velocity, should't the force be directly proportional to the velocity? I extract impact force from the target underlying elements (impacting object) because they seem to go back to zero as expected, when extracting from contact underlying the force doesnt seem to go back to zero ( I assume because this for the whole girder and not just the contact region maybe?? Idk, initially thought it will be same from both). I attached some screenshots to help.
