Ansys Learning Forum Forums Discuss Simulation Fluids Operating Density in Fluent Simulation Reply To: Operating Density in Fluent Simulation
Essence
In operating conditions, please use outlet density as operating density. Since, this is used to eliminate the hydrostatic pressure effects of air. Yes, you can set outlet pressure to 0 Pa, provided the operating density is applied correctly and is non-zero. It is generally recommended to use outlet density in operating conditions to remove hydrostatic effects.
