Ansys Learning Forum Forums Discuss Simulation General Mechanical Combination of seimic and structural analysis Reply To: Combination of seimic and structural analysis
Lydia
You can try the Solution Combination object 18.17.12. Solution Combination (ansys.com). I don't know which release you are using so I 'm not sure if the feature has its current capabilities. You shall check the corresponding help documentation.
