Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Springs in modal analysis. › Reply To: Springs in modal analysis.
peteroznewman
Hi Javat,
Animate the first and second modes. What is the principal direction of movement?  That is the direction where there is zero stiffness.
To eliminate all rigid body motion, you need a minimum of stiffness in 6 directions, and that is only sufficient if the directions are not redundant.
For example, if you have a frame that is attached to ground at 3 points, and ground is the X-Y plane with Z vertical, the first point can have stiffness in 3 directions (X, Y, Z).  The second point must be separated from the first point along the X axis and needs stiffness in the Y and Z directions.  The third point must be separated from the first point along the Y axis and needs stiffness in the Z direction. This is the minimum to avoid a zero frequency mode.
You can have springs with stiffness in 3 directions on 3 or 4 attachment points, that is fine and may increase the frequencies of some modes.
COMBIN14 is a 1D spring element, so to get stiffness in 3 directions, you need 3 springs. KEYOP(1) = 1 is for nonlinear damping. To get no rigid body modes, you would need 6 springs oriented in the correct directions as described above. If you wanted stiffness in 3 directions at 4 attachement points, you would need 12 COMBIN14 springs.
Use one COMBIN250 at each attachment point which is a spring element that can have stiffness in 6 DOF (X, Y, Z, Rx, Ry, Rz).
