Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Delete element after the failure of all integration points › Reply To: Delete element after the failure of all integration points
Ushnish Basu
Actually, IFAIL<0 in MAT_USER_DEFINED specifies the position of the parameter NUMINT in the constants array, where NUMINT specifies the number of integration points that need to fail.
