Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Metasurface High Q Factor Calculation › Reply To: Metasurface High Q Factor Calculation
Guilin Sun
this is a good question:h
if you know the mode profile, you can place the monitor to where shows strong intensity.
If you do not know the mode profile, you will need place the time  monitors randomly in space, in order NOT to miss the strong resonant mode. I
You may set the analysis group close to the boundaries.
