Ansys Learning Forum Forums Discuss Simulation LS Dyna Importing .k files in Workbench LS Dyna Reply To: Importing .k files in Workbench LS Dyna
igandiko
In terms of the solver, there is no difference between LSTC LS-DYNA and Ansys LS-DYNA. It is possible WB may not support or provide an interface for all the cards for input preparation, in which case, you can manually add the missing cards using a keyword snippet. You can import a .k file in WB, however, depending on the version, not all cards may get imported successfully. You can check the import summary for missing cards and add them manually. Note that if you have existing LSTC model and you simply want to run it, you can do that using LS-RUN (interface to call the solver and execute the run). LS-PrePost can also be used for pre/post processing.
