Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Serpentine cooling channel battery pack simulation temperature problem › Reply To: Serpentine cooling channel battery pack simulation temperature problem
July 5, 2024 at 3:56 pm
Thank you for your reply Rob.Â
Then If I want the heat passes through solid to fluid, what option do I choose?Â
And you mean if there are interface zones, Is it impossible to heat entering to the fluid?:Â The battery cells generate heat and cool by aluminum channel and the inside the liquid water flows. Then, the water temperautre also change.Â
