Ansys Learning Forum Forums Discuss Simulation General Mechanical Thermal Conductance Reply To: Thermal Conductance
dlooman
It could be the default convergence criterion is too small.  If that's the case, you can increase it manually in Analysis Settings; Nonlinear Controls; Heat Convergence => On by Specifying --Value or --Tolerance manually.
