Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › mesh the heat exchanger,error node 0: zone xxxxx connect to volume mesh › Reply To: mesh the heat exchanger,error node 0: zone xxxxx connect to volume mesh
Federico
Hello John,
this error from Fluent Meshing typically indicates a problem with the mesh, such as non-conformal, duplicate, or degenerate mesh elements. To resolve this issue, you should ensure that there are no overlapping bodies in the mesh. If the mesh overlaps in any region, it can cause this error.
I would suggest you consider using one of our guided worfklows to guide you through the meshing steps. You can learn more on the Watertight geometry workflow here: Tutorial on Watertight Geometry Workflow | Ansys Courses
