Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Uniformly Distributed load and Uniformly varying load › Reply To: Uniformly Distributed load and Uniformly varying load
peteroznewman
If you have a solid cube and apply a Pressure to one face, that will be a Uniformly Distributed load.
In the Pressure Details window, in the Tabular Data section, there is an Independent Variable. Change that from Time to the Y axis. Now you will be able to type in the starting pressure and the ending pressure as a function of the Y coordinate, which is a Uniformly Varying load.
