Ansys Learning Forum Forums Discuss Simulation Fluids Issue calculating the Reynolds no. in Fluent Reply To: Issue calculating the Reynolds no. in Fluent
n should be N, ie Newtons. That's Fluent being case sensitive.
I checked this yesterday in 2024R1, but looks like the system ate both posts.
Double check what you're calculating, but also update to the current version. R19 would have been about the first release of Expressions and you may have found a problem.
