Ansys Learning Forum Forums Discuss Simulation Fluids non-physical negative uds concentrations with small diffusion coefficient Reply To: non-physical negative uds concentrations with small diffusion coefficient
So the scalar is mimicking very fine particles. What other equations/effects are causing the scalar to move? If you have a mass sink near the wall are you also removing scalar field?Â
