Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Ansys Fluent free Decay Test Report Definition › Reply To: Ansys Fluent free Decay Test Report Definition
Assuming you have separate faces for top, bottom and side(s) monitoring min and max of x, y and z should work. You'll need to calculate the angles from that, a report based on an Expression of the monitors ought to give you the angle.
