Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Problem when assigning a surface from a recorded profile › Reply To: Problem when assigning a surface from a recorded profile
If you have translated, transferred and set the data correctly it will. Otherwise it won't, this helps work out what's going on in your model.
