Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Vacuum chamber – air extraction, from 1 atm to vacuum in a closed geometry › Reply To: Vacuum chamber – air extraction, from 1 atm to vacuum in a closed geometry
Staff aren't permitted to open files or links so you'l need to post images here.
If you monitor domain mass (volume report) as well as pressure does that make sense?
