Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Need help simulating the braking torque for rotating disc (eddy current braking) › Reply To: Need help simulating the braking torque for rotating disc (eddy current braking)
HDLI
Hello Jared,
       I do not see the torque result. Could you show it again?
       Could you enable eddy effect on the disk and have inner band? I am not sure why you have two coil terminals for one winding (one coil)? One coil should have one coil terminal for this 3D coil.
HDLI
