Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › ANSYS Mechanical won’t open and stays on Blank Gray Screen (Path environment va) › Reply To: ANSYS Mechanical won’t open and stays on Blank Gray Screen (Path environment va)
Gary_S
You may disregard the Proxy server message.
This is not a common occurance to be this difficult.
Before you reinstall, you may want to try uninstalling the Prerequisites from Windows Add/Remove programs, then reinstalling them via the ProductConfig.exe
 So,
 Run ProductConfig.exe
 Check Required Prerequisties. It will list the currently installed ones, and that none are needed.  Make a note of these.
 In Windows Add/Remove programs, find each of the Prerequisites, and uninstall them.
 Reboot.
 Run ProductConfig.exe again.
 Check Required Prerequisties...It should now list several that are needed.
 Reinstall prerequisites.
It may be worth installing on another machine just to rule out a local machine issue.
We generallly recommed laptops that are designated as a Mobile Workstation as these have higher-end graphics / CPUs / Memory and are intended for engineering / CAD applications, not gaming.
