Ansys Learning Forum Forums Installation and Licensing Ansys Products ANSYS Mechanical won’t open and stays on Blank Gray Screen (Path environment va) Reply To: ANSYS Mechanical won’t open and stays on Blank Gray Screen (Path environment va)
Ace R
And with the resetting .old maneuver after the "DISM /Online /Cleanup-Image /RestoreHealth" command, the problem persists. I'm gonna have to suppose reinstalling it is my only option as of now, and I'll try to check out the ISO files technique. Though I'm not exactly sure to what site you're referring to in the PS:.
The situation was overall unequivocally frustrating, but I appreciate your constant and swift help Gary.
I'm out of home right now and installing all of 2024 R1 is going to take a gigantic amount of resources, so I might not be able to provide updates before the maintenance. If the problem remains unsolved, while ruling out everything we mentioned earlier, what should I deduce to be a plausible profound cause to this?
In which case, are there any resources that do recommend good laptops that are likely to not have any root problem with ANSYS (while having a decent to powerful performance)? Any additional ones for the specific installation of ANSYS as described? Thanks again, and Best Regards
