Ansys Learning Forum Forums Installation and Licensing Ansys Products ANSYS Mechanical won’t open and stays on Blank Gray Screen (Path environment va) Reply To: ANSYS Mechanical won’t open and stays on Blank Gray Screen (Path environment va)
Gary Stofan
I had a typo:
DISM /Online /Cleanup-Image /RestoreHealth
Please try to rename the APPDATA v241 folder once more:
Open a File Explorer.
In the address bar, enter %APPDATA%
Press Enter.
Open the Ansys folder
Rename v241 to v241.old
None of the error codes are familar.
We normally don’t recommed uninstall /  reinstall, but sometimes the Zip download files do not extract properly.
I prefer to download the ISO files, then mount each and run Setup.exe directly from the forst mounted DVD drive letter.
Hint: The first “disk” is the one with 241-1.dvd, second is 241-2.dvd, and so on
