Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Problem when assigning a surface from a recorded profile › Reply To: Problem when assigning a surface from a recorded profile
javat33489
Sir, I did not understand your question. Can you write in more detail what you mean?
I think that if I transfer the flow from the outlet to the inlet, then the liquid will flow at the same speed as at the outlet, which is what we recorded in the file.
