Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Delete element after the failure of all integration points › Reply To: Delete element after the failure of all integration points
June 5, 2024 at 3:15 pm
Alex R.
Hello,Â
Failure can be incorporated in the material routine with IFAIL.
- IFAIL =1: the element is eroded as soon as first integration point fails.
- IFAIL<0: abs(IFAIL) states the number of integration points that needs to fail before element erosion.Â
Please let me know if that helps.Â
Thank you,
AlexÂ
