Ansys Learning Forum Forums Discuss Simulation Fluids Resolving Mesh Connectivity Issues Between Two Part Bodies Reply To: Resolving Mesh Connectivity Issues Between Two Part Bodies
V.P
Hi Iden,
This happens because the topologies are not shared. Use the "Share topology" option in SpaceClaim/DesignModeller/Discovery and then import the geometry into meshing. Or else if you are using Fluent meshing, there is an option to share the topologies at the 'Describe Geometry' step.
