Ansys Learning Forum › Forums › Discuss Simulation › Electronics › S11 as an output in Optislang › Reply To: S11 as an output in Optislang
Mrinmoy Bharadwaj
Hello Nicolas,
You need to first plot this single value of S11 in HFSS in a plot by selecting the specific frequency at which you want your S11. Save the design and close AEDT. Open Optislang, import the AEDT solver wizard and specify the path to the project. Once you see your plot name in the "Outputs" section in optislang, click and drag the plot to the "Responses" section like:
Go to the Variables section, and you should see your output as a [1:1] array as seen below:
To see the value of your variable, you may add an additional variable and in the expression section just use the function "$SIG_MAX_Y()" and press enter. You should now see the value of the S11 parameter in your response.
