Ansys Learning Forum Forums Discuss Simulation General Mechanical Result shows same value for max and min Reply To: Result shows same value for max and min
Sneha E S
I have applied load as point load at center of the beam. The boundary conditions are fixed and simply supported also three different materials are to be studied. For different cases I have obtained fatigue life with minimum and maximum value 0,10, 1+e8 etc. The plot for damage also shows the same values for those cases whereas safety factor has a contour plot with different values at different regions( adding an image, unable to add many pictures). I have to analyse the models with above conditions itself, cannot change any of those as my work is to study the fatigue behaviour in each case. So I just need an explanation for such results which I can use in my work. Also I am unable to access first link.
