Ansys Learning Forum Forums Discuss Simulation Fluids Ignition doesn’t start with GRI-Mech for methane Reply To: Ignition doesn’t start with GRI-Mech for methane
felix512
Hi Vijay, thanks for yor answer.
I don't understand your question; the "Chemical Equilibrum" or "Steady Diffusion Flamelet" are available for Non-premixed models. Here I'm using the Species Transport model, with GRI Mech 3.0 and EDC.
In the 1st case I had ignition : with a wall at 2000 K starting the ignition. The geometry had a bluff, which increase turbulence and so enable ignition.
In the 2nd case, I just removed the bluff, and keep the wall at 2000K. With this geometry, I don’t have ignition. I guess this is because there is less turbulences due to the bluff removed, while EDC needs turbulences to start chemical reactions (= ignition). I don’t know how to do…
I want to use the GRI Mech (so I need species transport model). I already tried to patch a high temperature, and all species at 0.01, but it’s also not working.
Even when I don’t put a volumetric reaction, or just the Eddy Dissipation model, I don’t have ignition.
Thanks for your help
