Ansys Learning Forum › Forums › Discuss Simulation › Photonics › MODE: Strange mode result from FDE solver › Reply To: MODE: Strange mode result from FDE solver
Hello Amrita,
thank you very much for your help.
I now tried both of your suggestions, setting n=2.18 and using fewer mesh cells for the background mesh.
Unfortunately, the error still occurs but interestingly only when I execute the code for the first time (e.g. after restarting MODE):
The effective indices of the found “false modes” are then equal to the effective index I set in the modal analysis tab. I re-run the (exactly same) simulation 20 times and only observed the error for the first run - which is at least significantly less than before. Moreover, I repeated the sweep of the waveguide top width with the new settings and run the code on a different computational server of my university, too. In both cases I made again the observation: for the first time running the simulation the strange mode result occurred.
Best regards,
Henrick
