Ansys Learning Forum Forums Discuss Simulation Fluids Simulation Airfoil NACA 0020 but the lift coefficient is 0 Reply To: Simulation Airfoil NACA 0020 but the lift coefficient is 0
Check the actual value as I doubt it's exactly zero. What lift would you expect at an airspeed of about 0.3m/s? You also need to review the mesh as non conformal interfaces are not needed for this sort of simulation.
