Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Using force data in ANSYS AQWA › Reply To: Using force data in ANSYS AQWA
June 4, 2024 at 8:50 am
Good morning,
In the Hydrodynamic Response component, when you run a Time Domaine analsysis, you can import a time history structure force from a CSV
Alternatively, you can also import a time history force as a XFT file. It you google XFT Aqwa force, you will get access to its format.
Kind regards,
Ingrid
