Ansys Learning Forum Forums Discuss Simulation Photonics question about getting the Barry phase as a function of the rotational angle Reply To: question about getting the Barry phase as a function of the rotational angle
Amrita Pati
Hi Carloso,
It looks like the approach would work.
I haven't gone through it in detail. You might have to rely on a purely scripted solution (as opposed to using the in-built sweep utility) to find the phase as a function of nanofin rotation (as you need some post-processing in between the sweeps). Or maybe you could do a sweep for different rotation angles, save the 'S_polarization" result and then perform the post-processing for all the parameter values at once. The exact methodology depends upon your preference. But let me know if you come across any issues.
Amrita
