Ansys Learning Forum Forums Discuss Simulation LS Dyna Problems with fatigue calculations Reply To: Problems with fatigue calculations
igandiko
Hello, how do the element stress results compare to the S-N curve? Do the elements showing low fatigue life have higher stresses/high damage ratio?
The expected fatigue life is computed as exposure time (in time domain, it is defined by termination time by *CONTROL_TERMINATION, also see texpo paramter) divided by cumulative damage ratio.
Regarding your question 3, expected fatigue cycles are computed as "expected fatigue life" times “zero-crossing frequency with positive slope”. For d3ftg generated in a time domain fatigue analysis, only cumulative damage ratio and expected fatigue life are provided. There is no “zero-crossing frequency” so no “expected fatigue cycle” is provided.
