Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How can I see average skewness values in Fluent Meshing? › Reply To: How can I see average skewness values in Fluent Meshing?
Petros
Hello Merve,
You can display min,max and average values of orthogonality, skewness and aspect ratio by going to Report-->Cell Limits... and in options choose Quality and from the Quality Measure... box choose the metric and the cell zone you want to examine and then compute. This will give the minimum, maximum and average values for that metric.
You can also do it through the TUI by typing report/quality-method and choose a metric. Then type: cell-quality-limits and type in the cell zone(s) whose metrics you want to see. If there's only one, then leave the prompt "Cell Zones(2) [()]" empty and press enter.
If you are using version 2022R2 or later, you can directly go to Mesh-->Quality-->Diagnostics Tools... and use the corresponding tool, which has also options to mark cells based on quality metric limits.
To find location and node number of problematic cells or faces, in the Outline right click on your Mesh Object and go to Diagnostics-->Connectivity and Quality and choose a quality metric as a measure, click on Mark and then cycle through the elements. Info will be displayed on the console output.
