Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Fickian diffusion › Reply To: Fickian diffusion
June 3, 2024 at 2:02 pm
Hi Prashanth,
Thanks for those links, I wasnt aware of all of those cases but unfortunately none of them demonstrate the phenomena I am looking for. I think in both of the cases you linked the main driver for mixing is from the turbulence generated by the flowing fluids.Â
The case I am considering is trying to eliminate all impacts from turbulent flow to demonstrate the impacts of only Fickian diffusion (Fick's laws of diffusion - Wikipedia).Â
As described above, there is a simple analytical solution for simple systems but I was hoping i would be able to use this to validate to use the model for more complex geometries.Â
