Ansys Learning Forum Forums Discuss Simulation General Mechanical ACOUSTIC – FLUID STRUCTURE INTERACTION Reply To: ACOUSTIC – FLUID STRUCTURE INTERACTION
castrohenrique0208
Hi Erik
I want to perform an modal simulation to extract the modes using only the panel, then the acoustic cavity and then the system panel+ acoustic cavity.
After I want to perform an harmonic analysis to extract the sound pressure level generated in the system panel + acoustic cavity.
I don't know if the video that you sent apply for this case, because I am using the acoustic body below the panel (surface not a solid), as you can see in the image.
My main goal is to extract the sound level pressure, but I'm a little bit ansure about the process.
I try to do as you said using the harmonic acoustic, but i'm still get it the same ? error when trying to apply the FSI.
I'm sending the link of the project, if you can see it would be great.
https://drive.google.com/file/d/1Z4rF8_8GrcDAtkhSrxcktSqV-H69sgCE/view?usp=drive_link
