Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › ANSYS Mechanical won’t open and stays on Blank Gray Screen (Path environment va) › Reply To: ANSYS Mechanical won’t open and stays on Blank Gray Screen (Path environment va)
Gary_S
The reason for the failures is that the Command Prompt must be run "As Administrator"
In my instructions:
You must have Admin rights to register..
You can confirm registration by pasting the following into a Command Prompt As Administrator
