Ansys Learning Forum Forums Discuss Simulation Fluids Rocky tutorial 14: fluent error Reply To: Rocky tutorial 14: fluent error
Lucas Bertollo Baggio
Hello Kiran,
how would you like to see the interactions? you can see the fluid side by coloring "CFD Coupling" entity in a 3D view by any property in Nodes, for example. To do this, create a new 3D view, make the walls transparent and click the CFD Coupling on the Data panel, go to the Coloring tab, make visible and check Nodes with the desired property.
