Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Write the parameter value to a text file › Reply To: Write the parameter value to a text file
Thanks for your response. I have started the simulation from the beginning and now its working. I would like to write the result of an element to the output file, i have tried using this command
esol,2,10,,bfe,temp
(ansys documentation reference ESOL, NVAR, ELEM, NODE, Item, Comp, Name
Specifies element data to be stored from the results file.)
complete code isÂ
RESUME
/post26
!nsol,2,22,temp
esol,2,10,,bfe,temp
/out,temp_solution,out
prvar,2
/out
However, this is not working and in the outfile, i can see the warning : PRVAR is ignored.
Can you please help me in writing the element temperature values w.r.t to the output file. If element values are not available, i would like to write the average of the temperature values of all nodes(for that particular element).
