Ansys Learning Forum Forums Projects & Partners Sustainable Engineering Fracture Propagation Study by FSI Reply To: Fracture Propagation Study by FSI
Atif Ismail
Thank you for your reply Mr. Khemka.
I have read the shared link.
I am comfortable in using SMART Crack Growth but I am unable to use that in two way-FSI (Structural and fluent).
Kindly confirm if SMART Crack growth works in two way-FSI or not? If it is possible if you may share any relevant reference for that.
How I select the fracture top face and bottom face as a coupling region?
As if I select the area A as a coupling region (Figure 1), the sif is highest at the point B and C where as SIF should be highest at the fracture front (yellow circled) (Figure 2).
If you may comment on the posted issue.
