Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Change view orientation and export result as avz › Reply To: Change view orientation and export result as avz
mjmiddle
Your command doesn't look right. It should be:
settings = Ansys.Mechanical.Graphics.Graphics3DExportSettings()    # only has background controls
ExtAPI.Graphics.Export3D(file_path, Graphics3DExportFormat, settings)
However, there are no settings to determine the view orientation, and I don't think the avz file format even supports this. It's just a simple format that contains the deformed mesh shape and contour.
Any view would be controlled be the Ansys Viewer application. However, I see no scripting capabilities in this application and no way to set the default view orientation.
