Ansys Learning Forum Forums Discuss Simulation General Mechanical Write the parameter value to a text file Reply To: Write the parameter value to a text file
mjmiddle
When you set the "Save MAPDL db" to yes it requires running the solution again. It's not marking the solution out-of-date when you change this setting and that would help enforce the correct action. Right click to "Clear Generated Data" on the solution after changing this setting and run the soution again.
