Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Write the parameter value to a text file › Reply To: Write the parameter value to a text file
May 31, 2024 at 8:19 am
I have tried as follows,Â
/post26
nsol,2,561,temp
/out,temp_solution,out
prvar,2
/out
However, i am able to create a output file(temp_solution.out), but i am getting an error.
I have found online, i should use save MAPDL db file to yes and i have changed it to yes. Please let me know, what else can i do. I have one more question to, i would like to print the element results to an output file using ESOL(average of all the node values of the element, if only node results exists in the simulation),can you please help me with that too. Â
