Ansys Learning Forum Forums Discuss Simulation Electronics Time Variable in Electric Transient Solution Reply To: Time Variable in Electric Transient Solution
GLUO
"time" is already an internally defined variable that can be used. Could you check if the name of your dataset is correct?
GL
