Ansys Learning Forum Forums Discuss Simulation General Mechanical [Mechanical APDL] Reducing element load balance ratio in a model with contacts Reply To: [Mechanical APDL] Reducing element load balance ratio in a model with contacts
Aniket Chavan
which version are you using? Which contact elements are you using? Please check the following page for more information about solving large contact models in DMP environment:
3.16. Solving Large Contact Models in a Distributed-Memory Parallel Environment (ansys.com)
-Aniket
Forum Rules & Guidelines
