Ansys Learning Forum Forums Discuss Simulation General Mechanical Problems with symmetry Reply To: Problems with symmetry
Akshay Maniyar
Hi Marina,
  1. Applying two symmetry regions to model a quarter of the whole structure is possible, but you must ensure that both the geometry and the loads and boundary conditions are symmetric across the planes you are using for symmetry. If you're not seeing the same stress results, it could be due to the friction contacts, as they might introduce asymmetry depending on how they behave under the applied loads. It's important to verify that the frictional behavior does not violate the symmetry conditions.
  2.  Symmetry can be applied either in the Design Modeler or directly in the Mechanical Workbench. The key is to ensure that the symmetry boundary conditions are correctly applied in the Mechanical Workbench to reflect the intended symmetry of the model.
    For other CAD tools, you can cut the geometry into it and then apply symmetry boundary conditions in mechanical.
  3.  For beam connectors situated on the plane of symmetry, you typically do not need to reduce their area by half. Instead, you should ensure that the boundary conditions on the symmetry planes are correctly applied. This might involve constraining the appropriate degrees of freedom to simulate the effect of the full model.
You can check the working load of the beam connections by inserting bolt pretension result or you can check axial force by using beam probe.
Thanks,
Akshay Maniyar
