Ansys Learning Forum Forums Discuss Simulation Electronics Variable Dimension Problems Reply To: Variable Dimension Problems
DimK
Hi Taiye,
Additionally, to my first response, please check and make sure that you use the appropriate modeler units, through: Modeler (Menu Bar)-> Units…
Also, check if the two lines that you refer to have the desired properties and if the design variables that you have defined correspond to them.
Best Regards,
DimK
