Ansys Learning Forum Forums Discuss Simulation General Mechanical Problem with artificial intervertebral disc Reply To: Problem with artificial intervertebral disc
Sampat Kumar
Hi
Can you try to apply the "add offset ramped effect" in the connection and see if this helps you or not?
Also, increase the number of substeps to capture the contact properly.
Best Regards,
Sampat
