Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › ansys additive material database › Reply To: ansys additive material database
May 28, 2024 at 10:38 am
If you check the material property values for Ti6Al4V, you will find that it has orthotropic thermal conductivity. You can check the material property values under Engineer database for othe rmaterials.
Thanks,
Akshay Maniyar
