Ansys Learning Forum Forums Discuss Simulation Preprocessing Difficulty in report files setup Reply To: Difficulty in report files setup
nilay.pedram
You can consider using the transient data sampling feature. This feature allows you to run a transient solution and enables the export of data, which could potentially include the flow velocity and temperature at each time step. As described in the provided context, you can create a new Fluent component for transient data sampling, which may help you to manage the data recording process more efficiently. Thanks!
