Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Question Rmxprt and Maxwell › Reply To: Question Rmxprt and Maxwell
Navya Chode
Hi el min,
If your phase winding has 7 turns and the wire used for each turn is 0.55 mm then, you need to use 0.55 mm as the diameter of the wire with the number of strands as 1.
If your phase winding has X turns and each turn is made of 7 wires of 0.55 mm diameter then, you need to use 0.55 mm as the diameter of the wire with the number of strands as 7.
Navya
